Painting caliper - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-11-2002, 01:30 AM   #31 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
well you could either paint right over it or take it out and either tape the iside of the hole or hold newspaper right behind it so that the paint doesnt get on the inside of the drum. either way works.
92CAMRYGTS is offline   Reply With Quote
Old 05-11-2002, 10:02 AM   #32 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I used Dupli-Color high temp engine enamel to paint my calipers, drums, valve cover, and pipes (intake piping).
It comes in 500 degree and 1200 degree.
"Skoolin' the unlearned!"
Old 05-11-2002, 09:31 PM   #33 (permalink)
RUN WHAT YOU BRUNG
i used the same stuff. i used the 1200 degree paint.
Old 05-11-2002, 10:30 PM   #34 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $307350
View bgrieger's Photo Gallery
1200 is overkill for calipers. Anything rated to 500 degrees will do you fine...get beyond 500 and the boiling brake fluids will likely be a greater concern!
Bob
<font size=-1>[ This Message was edited by: bgrieger on 2002-05-11 23:31 ]</font>
Old 05-14-2002, 07:55 PM   #35 (permalink)
The TN dissapearing act..
Dark's Avatar
View Dark's Photo Gallery
88LE where did you get those TRD calipers. do they only fit your model?
CE is for "Cheap Edition"
Dark is offline   Reply With Quote
Old 05-15-2002, 12:32 PM   #36 (permalink)
Grenaded piston
88 LE's Avatar
Their not TRD calipers. I just painted TRD on them. :grin:
Old 05-16-2002, 02:57 PM   #37 (permalink)
View tmanana's Photo Gallery
LOL...looks very clean none-the-less!
2002 National Sound Pressure League Record Holder....Hearing is Overrated
Hey look! Girls like my car, so they MUST like me
tmanana is offline   Reply With Quote
Old 05-17-2002, 06:02 PM   #38 (permalink)
The terrorist
View Xenon's Photo Gallery
That looks like a pro job man, good work..
I've painted my rear drums, but because they were badly rusted I had to sand blast them to save myself alot of time and labour, then I sprayed them flat black, but high heat paint..
It's alot easier just to take them off, and it's not hard to take them off, just hit it a couple of times and then jiggle it and it will slowly come out, sand it down with rough sand paper and then soft, if you start with soft it will take you weeks...
Good luck
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
