Painting caliper - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-15-2002, 07:40 PM   #1 (permalink)
ID
View ID's Photo Gallery
What would happen if I use regular car paint to paint the caliper? Would it burn? Or would it melt? Or it's ok?
ID is offline   Reply With Quote
Old 04-15-2002, 07:57 PM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
If you dont use hi-temp paint, there is a high chance it will probably either fade or chip. Just get hi-temp paint from Canadian tire or Pep Boys, its cheap.
latez.
ratko.org
Ratko is offline   Reply With Quote
Old 04-15-2002, 08:16 PM   #3 (permalink)
View Consynx's Photo Gallery
Caliper is the thing that holds the brake discs in place, right?
Consynx is offline   Reply With Quote
Old 04-15-2002, 08:54 PM   #4 (permalink)
it was all a dream
It holds the brake PADS in place, and when you press the brake it presses down on the rotor or brake disc.
latez.
ratko.org
Old 04-15-2002, 09:48 PM   #5 (permalink)
ahhhh!!! i was close :lol
thx again
Old 04-15-2002, 10:07 PM   #6 (permalink)
ID
how about 50 degree max? Also, can I use high heat paint to paint my valve cover?
Old 04-15-2002, 10:51 PM   #7 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
50 degree!?!?! Calipers get crazy hot! Dude, go to Crappy Tire or Home depot and just pick up a can of Tremclad High Temp Enamel paint in your favourite colour.
Good luck!
Phi is offline   Reply With Quote
Old 04-15-2002, 11:05 PM   #8 (permalink)
View bondobondo's Photo Gallery
you really mean 500 degree right?
bondobondo is offline   Reply With Quote
Old 04-15-2002, 11:21 PM   #9 (permalink)
ID
haha, yea I do mean 50 degree. And I know that sounds stupid but I just wanna know if it will actually "BURN". Because that's kinda scary u know. Anyway, thanks for the replies!
Old 04-16-2002, 12:50 AM   #10 (permalink)
it was all a dream
You have nothing to "worry" about if you paint it using the wrong paint. Worse case, it begins to look fugly and you redo it.
latez.
ratko.org
Old 04-16-2002, 01:01 AM   #11 (permalink)
its cool
i mean it will be the next hot JDM trend
frames coming from your burnign calipers
first it was led on valve stems,
now we have real flames coming from inside the wheels
that would be so mint
so jdm.....
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
Old 04-16-2002, 01:06 AM   #12 (permalink)
TN Track day addict
View Lafora's Photo Gallery
perhaps you've seen pictures of F1 cars braking.
ever noticed their rotors get red hot?
think that's paint? nooo, thta's HEAT
50 degrees?
ever touched a piece of metal at 50 degrees? it's fairly warm right.
but you know the boilign point of water right.
so you tell us if 50 degrees max would work or not :smile:
My blog
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap
Lafora is offline   Reply With Quote
Old 04-16-2002, 04:15 AM   #13 (permalink)
View ericlee303's Photo Gallery
Dude, just use Tremclad, any kind.
ericlee303 is offline   Reply With Quote
Old 04-16-2002, 07:34 AM   #14 (permalink)
ID
Alright, thanks!
Old 04-16-2002, 05:55 PM   #15 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
well from experience i could tell you 2 things. get high temp engine paint. i used the 1200 degree paint so i knew it would stand the temp. just a lil overkill. second use a high temp primer. when i first painted my drums it worked nice. but after a while even though i got rid of most of the rust, without the primer the paint didnt stay well. the paint started to chip. plus when you use the primer the paint will look brighter. so three steps.
1. sand off all rust and clean off dust.
2. spray 1 or 2 coats of high heat primer.
3. spray as many coats of the high heat paint as it takes to get to your desired color.
92CAMRYGTS is offline   Reply With Quote
