Gen-5 Fuel Filter -- Losing My Mind - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-10-2004, 08:38 PM   #1 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
I've searched several boards, including this one, and spent an infuriating hour or so with the toyota on-line service manual trying to locate the fuel filter in my 2003.5 (Gen-5) V-6 Camry. Toyota's only reference to a fuel filter in this car is in the tank mounted pump mechanism, to which you gain access by removing the bench portion of the back seat. And I'm not going there. There's no reference at all to what I consider a "traditional" fuel filter located somewhere up front in the engine room. I suspect that it might be going by some oddball name, thus the failure of my searches (fuel microparticle removal device, for example...).
I give up. [Hey, there's no "white flag" smilie...]. Can anyone save me from myself on this one...
ekpolk is offline   Reply With Quote
Old 05-11-2004, 07:40 PM   #2 (permalink)
The Regenerator
ekpolk's Avatar
Well, I guess I'm not losing my mind. I stopped by the dealer today to pick up a couple odds and ends, and asked the question. The only fuel filter in a Gen-5 Camry is attached to the fuel pump inside the gas tank. Access is through a cover located under the rear seat bench cushion.
Is it just me, or is this arrangement really fckd up??? Having to access, open, and enter the fuel tank to replace a filter does not seem like it's contributing to ease of service.
BTW, no smoking while performing this procedure. . .
Old 05-11-2004, 07:56 PM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $696665
iTrader Score: 6 reviews
View EKam's Photo Gallery
Dealership will tell you they never change fuel filters in any of the cars that they serviced.
I changed mine just few months ago @145K Km, it's got black liquid coming out when my mech sprayed water from the other end.
(Gen3 doesn't have fuel filter in tank.)
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 05-11-2004, 10:14 PM   #4 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
thats nuts... most normal cars have the fuel filter in the engine bay somewhere in the vicinity of the fuel rail(s).
ratko.org
Ratko is offline   Reply With Quote
Old 05-15-2004, 09:36 PM   #5 (permalink)
The Regenerator
ekpolk's Avatar
Agreed. It's nuts, but that's apparently the way the engineers decided to set up this car. At least by the diagram, the in-tank filter looks big. Just judging from the diagram, I'd say it looks somewhere between pint and quart sized. Alas, when it does need replacing, this won't be a job for the faint of heart (or for chain smokers either...).
Old 05-16-2004, 01:10 AM   #6 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
The Seat comes off quite easily i think just pull upwards on it.
I think the car is like this cause it has no return lines??
- Vince
VVT-i Owns is offline   Reply With Quote
Old 05-16-2004, 07:16 AM   #7 (permalink)
The Regenerator
ekpolk's Avatar
I'm sure the seat does come out easily. What bugs me is the relative severe invasiveness, and potential danger, for what should just be a simple canister swap. I replaced the fuel filter on my 1988 Civic in ten minutes. It plainly accessible on the firewall in the engine room, and slightly taller and narrower than a small tuna can. It was a snap. Fuel spilling was on the order of teaspoons. Now, I've got to risk incinerating myself and my car, not to mention further contaminating the tank, if I ever need to replace this filter.
Old 05-16-2004, 10:34 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Atleast you don't have to drop the tank to get to the pump.
Gen 2's don't have a access panel underneath the back seat. Gotta drop the tank.
"Skoolin' the unlearned!"
Old 05-16-2004, 09:22 PM   #9 (permalink)
The Regenerator
ekpolk's Avatar
ok, I will now humbly slink back under my rock thanking my lucky stars that I don't own a tank-dropper! I think if I were you, I'd be stretching a few layers of cheese cloth over the filler nozzle each time I filled up. That's incredibly stupid! Toyota designs are supposed to be more intelligent than that!
