3vz engine problem... no power - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-16-2004, 07:12 PM   #1 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i just replaced the engine in a 92 es300 because the old one was blown... the damn thing sucks! it is acting like it did before with the old engine, it lacks power incrediby. although the old motor ran like shit and couldnt hold idle... anyways, the new motor is in and its running and everything. it lacks power. thats about all i can say.
i put new spark plugs in, i did correct ignition timing with a timing light and everything is lined up right and stuff... my thoughts are either fuel pressure is too lowwhich means either bad fuel filter,pump or injectors... prolly filter, OR i need to replace the spark plug wires and maybe distributor cap too...
anyone ever have this problem or know what i should do first... this has already been pissing me off for a week... when i just thought it was the timing... but the timing is now set correctly and its still fucked up.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 05-16-2004, 08:39 PM   #2 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
No power as in accel? It could be low compression. Have a compression test run. Could be a bad head gasket or a leaky valve.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 05-16-2004, 11:21 PM   #3 (permalink)
I'm a Mac
zoni's Avatar
no its a good motor i put in... good compression... its gotta be either wires, distrib, or soemthing with the fuel...
Dave Zoni
Old 05-17-2004, 12:54 AM   #4 (permalink)
Auto-Cross Addict
Well, if it is misfiring ( bad injector, bad plugs), you'll know it for sure. It will have a really weird sound to it. Can't explain it cause it's been a while. But you will know it. Well, I don't think the wires would be the problem. Your probably right on the fuel pump. Check it out. A quick tear down and you could have it back on and cleaned out by the end of the day.
Old 05-17-2004, 04:51 PM   #5 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
How's the catalytic converter?
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 05-17-2004, 05:06 PM   #6 (permalink)
Auto-Cross Addict
Yeah, good idea. If it is an exact take off of the 92 Camry, the cat it a bolt up. Just take it off and go for a quick run around the block (no major streets. Cops don't like that ). See how it does. Make sure to warm it up first. No car is good on a cold start.
Old 05-17-2004, 11:30 PM   #7 (permalink)
I'm a Mac
zoni's Avatar
i thought it was the exhaust at first, well at second, after i did the timing... cause it was smoking out of the exhaust... seriously smoking, like there was a mouse next or something in there i think... so i took the exhaust off up to the y pipe, no cat or anything... and it still performed the same, like no power... so its not the exhaust
Dave Zoni
Old 05-18-2004, 10:16 PM   #8 (permalink)
Auto-Cross Addict
Are you running premium like every good 3vz owner should? hehe. Can't really think of anything else without being there. sorry. good luck
Old 05-19-2004, 03:09 AM   #9 (permalink)
I'm a Mac
zoni's Avatar
im not running anything bro... i have barely driven the car, it came to me with a blown engine, the only driving ive done with it (unregistered) is down the street and back to test the power... and it sucks... so i prolly used like .25 gallon of gas, from a gas can in my garage
nobody else wants to help me out, i know somebody must know something technical!
Dave Zoni
Old 05-19-2004, 06:29 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Have you checked fuel pressure?
How about the injectors? You can use a large flathead screwdriver, place the tip of it against the injector, and the handle against your ear. You should hear a clicking sound (this is the injector turning on an off).
Does the 3VZ-FE have crank position and cam position sensors?
"Skoolin' the unlearned!"
Old 05-19-2004, 09:57 AM   #11 (permalink)
I'm a Mac
zoni's Avatar
it does not... its got a distributer
i didnt really want to get into the fuel, but i guess ill have to...
Dave Zoni
