Originally posted by imlost
you can put a 3sge head on a fe block right?
Yes, but its not as easy as just bolting on the head. You also have to swap the ecu, wiring harness, etc...
By the way its not FE block. 3S-FE, 3S-GE, and 3S-GTE all share the same block (3S (3rd gen S block)).
F = narrow valve angle. 22 degrees.
G = wide valve angle. 45 degrees.
E = EFI (electronic fuel injection).
The cams on a G head design are independent. Whereas on a F head the intake cam drives the exhaust cam through a spider gear (on the camshafts).
and i think (but not sure) it will lower the com. ratio?????
I don't think so.
Comp ratio has more to do with the pistons.
and if a swap to the ge head could io then use rods and pistons out of a 3sgte, and would thgey fit the 3sfe crank??
Yes and yes.
But, if your gunna go through the trouble of swapping the head and internals, i'd do a 3S-GTE swap.
