Originally posted by Hatch
Ok yeh i guess it could get confusing but it is sometimes decieving when someone is bragging about their car saying that he is running 22psi when that could be thru a straw
Jeff
By measuring boost IN the manifold, there is a known quantity there. If you are running 20psi on one 5s-fe and 15psi on another of the same motor, you are comparing apples to apples (forget about porting for a second).
Talking about volume is important when talking about getting the right size turbo for the job, but once its on the motor, a turbo will flow what it flows...
Of course, 15psi at 3krpm is different than 15ps at 8krpm.... but so is 100ft-lbs of torque at 3k vs. 8k rpm...
Point being: If you know generally about the motor, just quoting psi will give you a pretty good idea of the power the motor is putting out and also how much stress the engine is under.
I can try to clarify more if you want...
-Charlie
