Who told you that? If they are both the same, it's not too big of a deal. Your tires will wear a little quicker to the inside, but not too bad. Do they make a camber kit for the Gen3? Who?
On 2002-04-23 18:51, trueno92 wrote:
OMG NEGATIVE CAMBER IS BAD!!!!!!!!!!!!
do i sense sarcasm? :smile: -1.7 and -2.0 is good..for the track hehe. but i dunno why it's uneven? that's odd. but yea, tire wear will be occuring on the inside more than anything. no biggie, any lowered car will have more negative chamber...as long as ur not getting some crazy numbers like -4!!
it is probably the same or the change in either side is so minute it is insignificant.
the laser machines for alignments are so sensitive now, camber changes when you are in and out of the car. not to mention toe changing with the angle of the tierod end..
+/- 0.3 degrees is pretty negligible for camber......
don't take those readouts too seriously, i would put money that if he mounted your car 2x in teh same day, both readouts would differ from one another.
siu-sum loy-yun
nothing is forever æ92.FF.pilot
well i got my 86 set at about 8 degrees of negative camber. its sooo fat!!! wheels popping out and all!!! i've noticed its super easy to get the car sliding though. so wicked!
Nick
EIGHT DEGREES?! arent u losing traction instead of gaining then? i doubt ur suspension is gonna flex that much :smile: but koool if u can get it to slide more easily!! hoho
On 2002-04-24 23:37, fatredcircle wrote:
You may doubt it, but if you look at it, you'll see that it does flex. It sits out a very good deal, which is very noticable.
wow it flexes so much that u get a full contact patch when u corner with ur 8 degrees of chamber? that is some major flexing :smile:
