Originally posted by Flashmn
Disengage more fully eh? I'd say if your clutch doesnt disengage fully you have some serious adjustmental issues, that would require repairs.
Excerpted by a post by TheMAN on a Protege forum, an extremely knowledgable enthusiast about stainless braided clutch lines... (I may have been a little off)
"The clutch line itself is just like any brake line and is used for the hydraulic clutch system. It allows the clutch to be disengaged by hydraulic pressure. Most of the system consists of hard lines (just like the brake system), however at one point where there must be accommodations for movement (because the whole powertrain unit rocks back and forth), a flexible line must be installed. Just like swapping the stock brake lines to stainless steel ones, swapping the clutch line will also help increase modulation control (easier to slip the clutch during shifts) and allow the disengagement of the clutch to be complete (especially so for aftermarket clutches that have heavy pressure plates)."
http://www.clubprotege.com/forum/sho...ghlight=clutch
