'94 Corolla won't start sometimes, will others... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-23-2004, 10:15 AM   #1 (permalink)
View Lee280zx's Photo Gallery
I recently purchased a 1994 Toyota Corolla. It is an automatic, if that matters.
Occassionally it won't start. Usually starts normally. I'm not the main driver, but I'm told that when you put the key in and turn it the warning lights come on (as they should to check the bulbs), but then when you turn it all the way to start it, there is nothing. I don't think there is even a clicking, though I'm not sure.
This happens both when the car and engine are cold and when they are hot.
Eventually the car will start again if you just keep trying to start it, usually within a few to several tries (without even shutting the car off, just keep turning the key all the way to that momentary start position).
A relative had this same problem with her 1995 Corolla, but ended up selling it before it was fixed. So I'm thinking this might be some sort of typical issue.
Has anyone had this problem? Can you tell me what needs doing or checking?
Lee280zx is offline   Reply With Quote
Old 06-23-2004, 01:10 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Sounds like the Starter is going or some relay or wire is shorting out. Search the tech forum for other threads about this.
I will move this to tech for you...
-Chris
Chris Corolla S is offline   Reply With Quote
Old 06-23-2004, 07:43 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
My mom's 95 Rolla did the same thing. The starter would click, but not turn over.
The starter contacts were worn out.
Heres a good thread about rebuilding starters:
http://www.toyotanation.com/showthre...312&forumid=10
"Skoolin' the unlearned!"
Old 06-23-2004, 07:53 PM   #4 (permalink)
Gonzo Journalist
biggriggs's Avatar
View biggriggs's Photo Gallery
exactly, starter contacts are worn out. cheap fix if you can get the starter out of there yourself and put it back in.
My 99 Camry was beaten to death by a phone pole. Now I have an 89 corolla SR5, I gained 10 years and lost about 100 HP, YIPPIE!
"You kids today with you loud music, Dan Fogelburg, Zima, hoola-hoops and Pac-Man video games. People have attention spans that can be measured in nano-seconds."
biggriggs is offline   Reply With Quote
Old 06-23-2004, 08:25 PM   #5 (permalink)
Thanks for the answers.
Is the starter hard to replace in this year of Corolla? I've replaced them in a first generation 300zx and a 280zx without much problem. I guess I'm asking if there is a bunch of stuff in the way that must first be undone, or if it is some awkward position, etc.
Thanks!
Old 06-23-2004, 09:14 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
^ Not sure about a 94, but on a 95 w/4A-FE (1.6L) the starter is on the backside of the engine.
Its a bitch to get to. I removed one of the bolts from the top of the car (you'll have to look for it). And the other bolt from the bottom of the car.
Then you gotta get it out somehow, which is also a bitch.
