On 2002-05-11 23:56, Den wrote:
Anything that I can do to improve the acceleration of my GEN3??
Are those octane boosters working?
If so, which one is better?
None of them do work. If you want to try the cheap route - put some whisky on your fuel tank and see if that helps.
What does engine flush do?
Flush the oil from the engine???
Will I get better acceleration if I use 94 octance gasoline? big differences with 91??
(I assume you have a 4-cyl.) No, because your engine is not high compression.
How many horsepower should a V6 or 4 cyls. Camry Gen 3 have?
V6 - approx 145hp at the wheels
i4 - less than 99hp at the wheels
Does engine treatment, likes Slick 50, help my acceleration? B cox my engine has 255,000km on it.
Don't think so.
