VENOM FUEL UPGRADE AND VENOM 400 for 94 CAMRY - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-14-2002, 05:58 PM   #1 (permalink)
View jay bee's Photo Gallery
Hi, I just wanted to know if anyone here has upgraded their V6 camry (94 preferbaly) with venom hi flow injectors and fuel pump and also with the venom 400?? The reason I ask is because I cant find more info on the venom 400, is it a nitrous system?? I think it just feeds a better fuel mixture to the system thats all....Anyone else have a computer chip in their V6 camry??? Any info would be great...
jay bee is offline   Reply With Quote
Old 05-14-2002, 08:22 PM   #2 (permalink)
Repatriated POW
View supraturbo's Photo Gallery
The venom 400 is essentially a piggy-back computer.
Here's a better description 4U in case you wanted to know...
"The Venom400 performance control module
an add on control unit that features it's ownmicro-controller. This module is connected to the throttle position sensor and the Manifold absolute pressure sensor, and by monitoring the sensors output characteristics. modifying the input signal to the vehicles existing ECU."
Application List:
http://coximport.com/venom/toyota.html
Misc Information:
http://www.fuelparts.com/Venom%20400.htm
So, if that helps....kew.
....yah....work is boring.
(¯`·._.·[ s£ïm ]·._.·´¯)
-87 Supra Targa Turbo-
supraturbo is offline   Reply With Quote
Old 05-15-2002, 12:45 AM   #3 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
honestly man.. its not worth it to do that... cos ur car will not be able to use all that fuel u are giving it.. unless ur engine requires it (s/c or turbo) so wasting ur cash on it...
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 05-15-2002, 02:25 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
As far as the injectors and fuel pump you don't need it unless you have something on your engine that requires more fuel, but even then you might not have to upgrade the injectors and fuel pump.
As for the Venom 400 its a computer that fools your ecu into thinking that the tps (throttle position sensor) is open more then it really is. Its a waste of money imo.
"Skoolin' the unlearned!"
