Ignition system - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-19-2002, 01:34 PM   #1 (permalink)
Ontario's King of AW11
View yellow86MR2's Photo Gallery
How can I check if my ignition system is working properly. Do those ignition amplifires realy work. I don't wan't to spend 800 for an HKS unit. That Jacobs ignition unit looks nice.
yellow86MR2 is offline   Reply With Quote
Old 05-20-2002, 01:30 AM   #2 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
dude the MSD is half the price and does the same job as HKS ... actually better if u can afford the digital MSD!!! hehehee
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 05-20-2002, 01:04 PM   #3 (permalink)
Do you know the actual price for the MSD unit? How hard would it be for me to install in my 86 MR2?
Martin
Old 05-20-2002, 01:39 PM   #4 (permalink)
Blazin...
the install itself isnt hard... but the main thing u gotta buy is the transformer toyota's require a transformer... without this boom ur msd ignition box is fried... normally if u wanna do install u'd email msd themselves for the iwiring diagram of ur car... just tell them ur car engine and year u should be easy... but dont forget to get the trasnformer .... price range is from 200-600 CAD depending on which one u got... im using the MSD SCI at the time whne i got it price was 250 now its only 200 so not a bad buy the digital ignition system run at about 400-600 depending on model i think...
hope this helps ya.. let me know if there's anything else...
humpty
Neoscepter
Old 05-21-2002, 02:13 PM   #5 (permalink)
Banned
View goodcookiedrift's Photo Gallery
are the msd 7al and the 6al essentially the same?
Nick
goodcookiedrift is offline   Reply With Quote
Old 05-22-2002, 02:28 AM   #6 (permalink)
Blazin...
no they do similar things but completely different ways if u have msd7al in ur car its not for street use so u're just wasting ur cash unless u got a super done up mod in ur car that will require the 7al.. the 6al and SCI-L are essentially the same ones though....
hope this helps...
Neoscepter
Old 05-22-2002, 12:24 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Depends which one you buy.
Installation is pretty simple. Theres 6 wires on the box itself. You got power (+12V), ground, 2 trigger wires, and 2 output wires to the coil.
Theres also a little plug on the box thats for a magnetic pickup. The tach adapter (MSD 8910HEI / 8910EIS) plugs into this.
The hardest part to figure out is which 2 wires to splice into for the trigger. On my 88 Camry I spliced into the ignitor and unpluged some plug so that the stock coil no longer works.
If the stock coil on your car is internal like mine is you'll have to drill a hole in the distributor cap and mount on a post. This is if you want to use a external coil (MSD Blaster). If you use the stock coil with the MSD or if your stock coil is external you don't need to modify the distributor cap.
Don't forget about the tach adapter. You need MSD 8910EIS.
"Skoolin' the unlearned!"
Old 05-22-2002, 05:56 PM   #8 (permalink)
Banned
okay that makes sense now...guess i need the 7al then...
Nick
Old 12-01-2002, 10:10 PM   #9 (permalink)
View Rolla GT-S's Photo Gallery
msd costs less than jacobs, but i like how jacobs doesn't require cutting wires, but i heard bad stuff about their ignitions. any one know how to install MSD in a 4age? will it need an adapter?
Forever 4A-GE
Rolla GT-S is offline   Reply With Quote
Old 12-01-2002, 10:16 PM   #10 (permalink)
View Deep's Photo Gallery
Yeah it will.
Deep is offline   Reply With Quote
