Roll Center Adjusters...drifter's best friend... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-23-2002, 02:36 AM   #1 (permalink)
DriftStar.com KingPin
View driiift_hachiroku's Photo Gallery
besides an LSD, a Roll Center Adjuster is one of the essential elements to tuning your AE86 suspension.
An RCA goes in between your strut casing and the lower-control arm on the front suspension. It's basically a block that returns your control arms back to "normal" position, instead of parallel to the ground on a lowered car.
There are some Negative Roll Center Adjusters that are set up to add more negative camber and front track width. I installed a BattleVersion NRCA today, and you can really tell the difference.
Problems that it alleviates:
Bumpsteer
Bodyroll
Understeer on turn-in
steering effort
and NRCA's defintely make the AE86 look mean on full DEMONCAMBER setting.
Jover
http://www.driftstar.com
1985 AE86 Corolla GTS Coupe
4AGZE (Supercharged)
driiift_hachiroku is offline   Reply With Quote
Old 05-23-2002, 06:31 PM   #2 (permalink)
View bondobondo's Photo Gallery
just a question
can any part of the rear suspension be adjusted for alignment?
or is it a total fixed axle?
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
bondobondo is offline   Reply With Quote
Old 05-23-2002, 11:33 PM   #3 (permalink)
Banned
View goodcookiedrift's Photo Gallery
total fixed axel...you could only adjust the lateral rod aka panhard bar so that it tracks evenely on either side....ussually loweirng the car alot warants an adjustable laterla rod...ie: jover and george
nick
goodcookiedrift is offline   Reply With Quote
Old 05-27-2002, 01:26 AM   #4 (permalink)
ahh ic
every think of those rigs like on them crazy ae86's that are welded onto the diff?
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
Old 02-05-2003, 11:39 AM   #5 (permalink)
View Artsi's Photo Gallery
Heaps of stuff are worth adusting at back.
Too bad there are no means to adust them on OEM trim cars. For example altering rear axle support arm geometry would consist of some welding, grinding and accurate drilling.
In racing car suspension one just would undo bolt, shift arm to adjacent fixing position and redo the bolt.
Despite solid rear axle construction in older rwd cars, we can adjust camber and toe-in within very narrow margin.
This coupled with attention to support arm attitudes is worth the effort - in my opinion anyways.
-A.
Artsi is offline   Reply With Quote
Old 02-06-2003, 10:14 PM   #6 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
oh boy...jover got some more crazy stuff.
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
