New IAC Valve
Hi all, well had some stalling problems and had dealer install a new IAC valve in my 97 Camry 4cyl. New IAC valve fixed problem no more stalling. A note on paper work said they also cleaned throttle body.
I have noticed one difference since new IAC. The early morning cold starts- the RPMs go up to about 1800 but instantly drop to 1200 rpms staying there instead of my usual 1800 or 1900 cold RPMs . then eventually going down to the normal 600. I did not think replacing the IAC valve would cause any difference in the cold start rpms. I assumed that was set by the ECU. Engine is running well but I am wondering why the cold rpms would change and be lower ? My area ambiant temperature is about 80 degrees right now, winter is usually in 30s. Could that be a factor, I always remember it going right up to 1800rpm if left for 24hrs regardless of outside temp. Any inputs appreciated
Vince
