Could this fit in a 2000+ tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-18-2004, 10:37 PM   #1 (permalink)
jeremy89's Avatar
View jeremy89's Photo Gallery
Question Could this fit in a 2000+ tacoma
GM Performance Parts ZZ383 Crate Engine
http://www.jegs.com/cgi-bin/ncommerc...83&prmenbr=361
Specifications:
Horsepower: 425 @ 5400 RPM
Torque: 460 lb-ft @ 4500 RPM
Compression Ratio: 9.7:1
Block: Cast Iron, 4-Bolt Main, 1-piece rear main seal
Crankshaft: Forged 4340 Steel, Externally Balanced
Connecting Rod: Powdered Metal (Special ''383'' Version)
Pistons: Hypereutectic Flat top with offset pins
Camshaft: hydraulic roller, 222°/230° @ .050'', .509''/.528'' lift, 112° centerlobe
Cylinder Heads: Aluminum Fast Burn 62cc chamber, 210cc intake runners, 2.00'' hollow stem intake/1.55'' sodium filled exhaust valves, LT4 Corvette valve springs and lightweight retainers, D-shaped exhaust ports and dual intake manifold bolt pattern and standard & center bolt valve cover paterns
Rockers: 1.5:1 Aluminum full roller, self-aligning
Water Pump: Cast iron, Long style, standard V-Belt rotation with 1979-86 power steering pump boss
Additional Parts Included:
8'' balancer
12-3/4'' automatic flexplate
4-quart oil pan with windage tray (5-Quart capacity with PF35 filter)
Painted valve covers with oil cap, and grommets, provisions for PCV breather
Composite (plastic) Front timing cover
Spark plugs
Engine oil dipstick and tube - passenger side location
Brass freeze plugs
Fuel pump block off plate
Engine lift tabs
Sic Vis Pacem Para Bellem!! "If you want peace then prepare for war"
jeremy89 is offline   Reply With Quote
Old 09-19-2004, 12:13 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Sure it will.....
Old 09-19-2004, 08:42 AM   #3 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
For that price plus custom work its not worth it you can turbo the Taco and get more HP ..
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 09-19-2004, 10:08 AM   #4 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
I know they make a kit to drop in a 350 into the Hi-lux(Truck before the Tacoma) So I am sure you can easily fit one in there with no problem. A few things you are probably going to need to do though are get a different tranny(Chevy Turbo 400 would be best) and custom mount it. Get a rear end that can hol that much power(Toyota 8" rear ends can hold a lot but with the power that motor is putting out and if you do anything else to the motor you might want to think about a Ford 9". You will also need at least a 2 or 3 row radiator and custom mount it along with a few other things custom mounted. It would be a pretty bad ass truck if you could do that but personally if you have a V6 you will be better off building the internals on it up and putting the TRD supercharger or turboing it. With that you will save money and you will have a more reliable truck.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 09-19-2004, 10:16 AM   #5 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Yes it sure will! Go to the Yotatech forums.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 09-19-2004, 02:00 PM   #6 (permalink)
jeremy89's Avatar
he scared me with that lol i was wanting to just drop the engine in and be done with it not have to do anything else ( differ tranny and the rear ends
Old 09-19-2004, 02:03 PM   #7 (permalink)
jeremy89's Avatar
yoo im thinkin though of getting me some Long headers( or shorties) um with Dual exhaust prolly Flowmaster (H pipes) with a trd turbo then prolly get another custom turbo
