Air Conditioning Coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-30-2002, 07:45 PM   #1 (permalink)
View 92CamryV6's Photo Gallery
Does anyone know what kind of coolant a 92 Camry uses?
-PJ
"Smokey"
92 3VZ-FE V6 Dark Blue Dark Blue Leather
152,000 miles should I mod?
http://www.geocities.com/pj10383
92CamryV6 is offline   Reply With Quote
Old 05-30-2002, 11:52 PM   #2 (permalink)
View old1985Corolla's Photo Gallery
Are you asking what refrigerant? If so, I'm pretty sure it would be R12, cars built 1995 and later use R134-A, if your car has R12 and has leaked out, you can either convert to 134-A, or there are some new alternative "drop in" refrigerants, going to 134-A, you have to change compressor oil, hoses and all seals, add 134-A test/charging ports, the newer alternative refrigerants will work with your oil and hoses now, just fix the leak first, then pull a good vacuum for about 45 minutes, charge your new refrigerant in to roughly 80% of what your R12 info plate shows from the factory. Only thing, you have to have a licesnce to buy most refrigerants, here in California, anyone can still buy 134-A, I like a newer one called "Freeze 12" it is very close to the operating temps of R12. If you look up Freeze12's website, it has a test you can take to get the licesne, it cost about 50 bucks I think.
1985 Toyota Corolla GTS, over 300,000 miles on original engine with no rebuilds, just good maintenance, 5 speed
old1985Corolla is offline   Reply With Quote
Old 05-31-2002, 12:03 AM   #3 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
It takes R12...I'm getting the conversion to R134a done next week, it'll cost me around $300 Cdn (at T-Lex). Everything mentioned above will be included, however, I will be getting a new filter as well (about $80). However, another company quoted me only $125 for the whole conversion, but no filter.
Anyone know if it's necessary in the long run to change the filter?
Silver Streak is offline   Reply With Quote
