Autometer OilPress gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-03-2002, 09:15 AM   #1 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Aaah, just returned from a month long vacation in Europe and I got my hands on a metrical autometer oil pressure gauge which I was trying to find for a long time. It's a mechanical one cuz they're more accurate. Now heres the question, how would one go about to plugging it in? I mean the block isnt NPT threaded where I could just T- the gauge and sender lines, right? Plus the "straw" that came with the gauge is really weak looking, would you use somethign instead of that, for example a brakeline brasstube, etc? any ideas how to proceed with the installation?
Old 06-03-2002, 09:39 PM   #2 (permalink)
View ADent55's Photo Gallery
I haven't messed with a mechanical oil guage since my '74 Lotus Europa, when I put a Stewart-Warner unit in (the stock Smith's guages were a joke), but my guess would be a metric tee off of the site where the electrical idiot light guage would be the best place -that way you can keep the idiot light, too. Since you'd be running a compression fitting onto the pressure tube, it won't care whether it's metric or SAE. I agree the plastic tube looks flimsy,and you'd think the thing would melt from the hot oil, but mine worked like a charm and so should yours so long as you don't have a kink (fold) in the line. And heaven help you if the fittings come loose (hot 10W-40 at 50+ psi will put you in a REAL bad mood), but mine never came out unless I told it to. Running brake lines is not only overkill in size, a hard line like that is asking for trouble from a vibration standpoint. Good luck!
ADent55 is offline   Reply With Quote
Old 06-04-2002, 04:01 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You could run a tap into the head. Something like 1/8" NPT.
Or you could try and find the right fittings and adapters to make everything work.
As for the lines I wouldn't use hardline (metal tubing). I suggest stainless steel braided lines.
"Skoolin' the unlearned!"
Old 06-04-2002, 09:17 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Well... I'll figure something out before I install it, I'm not gonna hurry with it, I'll do it when I start my engine mods now that I know I'm taking my car back to europe after I finish my stuff over here :wink:
Yeah, the guy in the shop suggested a braided line just to be safe, I'll se if I can find a place which sells hydraulic parts, get some hydraulic hose from there, should work just fine :smile:
Old 06-04-2002, 11:01 AM   #5 (permalink)
Banned
View goodcookiedrift's Photo Gallery
you can actually get the npt fitting from autometer so that it fits japanese vehicles.
i had to get one for my water temp.
Nick
goodcookiedrift is offline   Reply With Quote
Old 06-04-2002, 03:21 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Can I get it from a pipe shop?
Old 06-04-2002, 09:54 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
I don't know if pipe shops have metric stuff or not.
You need to know the size and the thread pitch.
Old 06-05-2002, 08:31 PM   #8 (permalink)
View Iceman's Photo Gallery
The plastic tubing supplied by the manufacturer is the correct pipe to use. Anything else is a waste of money. The pipe supplied is used daily on purpose built racing cars and fails very rarely. Keep It Simple.
Iceman is offline   Reply With Quote
Old 06-06-2002, 03:21 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Well, to be honest, it seems to be a bit short, I'm still wondering on using copper tubing, some use that and you just make loops at both ends to have it "flex" to relieve stress... wouldnt cost that much either...
Old 06-06-2002, 10:04 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
If you use hardline (metal tubing) you need to flare out the ends, which means you need a flaring tool.
By the time you buy a flaring tool, the fittings, and the tubing you might as well buy stainless steel braided hose and AN fittings.
I suggest that you use stainless steel braided hose and AN fittings. Its pricey, but your not gonna find anything else better then AN stuff.
Old 06-06-2002, 03:29 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Hmm, yeah I know thats a good choice and thats the choice I'd like, BUT I dont know where I could get braided hose... Plus then I need a gauge pod or a cup to install it to. On the otherhand, I've thought about getting another dash frame to mod and to install the oilpress and few other gauges there and switching the radio position down beneath the AC controls.
Old 06-07-2002, 02:55 AM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Check with some of your local car performance shops.
Summit Racing (mail order company) carries stainless steel braided hose and AN fittings (Aeroquip and Earls).
Old 06-14-2002, 05:29 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Ok, its wired with thin copper hose. should last longer than that silly autometer straw. Still gotta wire the light.
Old 06-14-2002, 11:44 AM   #14 (permalink)
Grenaded piston
88 LE's Avatar
Cool.
Yeah the hose included with their guages is useless.
1. Its not long enough.
2. Its small and looks flimsy.
When I installed my boost guage I got a 1/8" NPT to barb fitting and used a vucumm hose. The hell with that little hose they give you. :grin:
Old 06-14-2002, 11:58 AM   #15 (permalink)
Resident asshole
Flashmn's Avatar
Heh, I still gotta buy a gauge pod too ;P right now I got it on the dash with some putty (hehe, playdoh rulz)... had to do some custom plumbing at the block, but it seems to work now, plus I got the idiotlight attached aswell. its really neat, gonna see if I can meet up with a pal of mine tom. to find the gaugepod...and maybe something else.. :wink:
