If we got forged pistons, I may be more inclined to try double-digit boost. My goal right now is 8psi consistently, which should give 200 whp.
Here's a few pics to help us visualize everything. First, Sam's custom 4A-FTE setup:
A pic of the 5S-FE engine bay (on my Camry, but should be similar as the 5th and 6th gen Celis):
Other thoughts and questions:
- Manifold can be off an MR2T as well, since its got the same engine as the All-trac; but I'm wondering how it affects the orientation of the turbo. Since the throttle body is on the driver side, it makes sense to have Ithe exit to the intercooler on the passenger side, go through the intercooler, and come back up the driver side. In this setup, the air filter on the turbo will be on the driver side. You will see that Sam oriented his turbo the other way, which makes for more difficult bends on the exit to the intercooler.
- Relocating the battery would be a good starting point for a turbo project. I say we make that a TN DIY day. I already got rid of the cruise acuator (big box beside battery) to open up more space. However, this requires a different throttle cable.
- Depending on what your power goals and car usage is, determine the characteristics of the turbo you want. For me, I'm looking for a fast-spooling turbo (3500+ rpm) with street-usable power.
- Given most of us are talking about the 5SFE (2.2 I4) engine running low boost, what is the optimal diameter for the intercooler/intake piping, downpipe, and exhaust?
- Fuel management: I know we'll need a fuel pressure rise. Do we need a higher capacity fuel pump as well? Do we have fuel return lines on our engines?
- Any thoughts on managing spark timing? I have heard that retarding the spart timing would speed up spooling.
_________________
Jeff - SXV10
All Show + No Go = Drive Slow
Pictures Mods List
<font size=-1>[ This Message was edited by: SpectraBlueCam on 2002-06-11 13:19 ]</font>
