CV Joint Failure, or vehicle DEATH??
Hey all - this is my first post up here, just thought maybe some of you could help me do a little troubleshooting - as I haven't done much work with front wheel drives.
My girlfriend's 1994 Corolla has 180K on the clock, still going strong - except for this brand new knocking from the front axle/CV joint area whenever the car is under power (read: in Drive, accelerating or maintaining speed). It is not an engine knock. It doesn't sound like a wheel bearing - the noise is when you are accelerating in gear, straight forward or during turns. If it was a rear wheel drive car I'd say it was the driveshaft.
When you are going 40 MPH, for example, and you drop in in neutral - no noise. When you drop it into drive, no noise - when you step on the accelerator - whump, knock, whump, whump, clunk, knock (shudder, shudder) - all from the low front end. It sounds more prevalent on the right side, but it's on both sides.
The suspension in the car is pretty shot - and now I'm assuming the CV joints have gone bad.
So, I'm pretty mechanically inclined and I have replaced some CV joints before - but it's been a LONG time. Anyone have any proceedures for removing/changing them? I recall it was very easy. I'm prepared to roll up my sleeves and attck this job head on - just need a refresher course.
Thanks in advance
