Hub Centric Wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-04-2004, 01:34 PM   #1 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
Hub Centric Wheels
Recently I've been having disagreements with others on the importance of hubcentric wheels.
A) They help center the wheel correctly
B)Help reduce the loading on wheel studs
So are they needed or not? Lets hear some intelligent conversation and facts.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 11-04-2004, 01:50 PM   #2 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
I recommend them whenever possible, mainly due to the fact that anything that can help hold your wheels in ballance is a good thing. However I dont think that you should worry about the load on the wheel studs, mainly due to the fact that they are at least grade 8 bolts with a combined shier strength of probably 50,000lbs+.
Hatch is offline   Reply With Quote
Old 11-04-2004, 05:21 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://www.toyotanation.com/showthre...threadid=15167
"Skoolin' the unlearned!"
Old 11-04-2004, 06:50 PM   #4 (permalink)
VVT-i Owns's Avatar
Ya I read that thread before.
Anyone else?
- Vince
Old 11-04-2004, 07:45 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395360
iTrader Score: 13 reviews
I'd say more for the balance....
and also for the ease when bolting your wheels back on...afterall, why not anyway? they don't cost much at all
HaHa
Old 11-06-2004, 01:13 AM   #6 (permalink)
Owners of a Solara & Vitz
iTrader Score: 6 reviews
View CDNVITZ's Photo Gallery
What he said! I recomend them ease the load baring on the studs.
-Rick
2007 Vitz RS
CDNVITZ is offline   Reply With Quote
Old 11-06-2004, 11:15 AM   #7 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $696665
View EKam's Photo Gallery
Re: Hub Centric Wheels
That link from 88 LE summed it up.
Well, that's just like asking do you really need to wear a seatbelt? Some morons don't think they do.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
Old 11-22-2004, 04:13 PM   #8 (permalink)
View ALWilson's Photo Gallery
Hub centric/ lug centric ???
Where to begin? I learned about this debate the hard way. I have a 97 T100 2WD nice truck so I bought nice tires, but when I left the shop it was shaking pretty bad. Went back and the tech say, oh that machine must be bad we'll rebalance over here.... Me and this tire shop got to be close because they provided 3 new sets of tires, finally they washed their hands of it and said they could do no more. I found a shop that took on the problem, the matched balanced my wheels and tires and it got better but still shook at some speeds, then I learned about this Hunter 9700 Load force machine took it to the dealer, twice and it still shook.
One day kicking around the web I heard the lug centric theroy. Even found out Toyota has a Service Bulletin out on this subject, SU 002 96 which talks about using an adapter for truck wheels with 4 inch or larger center holes. My dealer has the SB but not the adapter.
Bottom line, I found a shop who had the Hunter Load force machine and the adapter, problem solved, no more shake.
Why did it work? Why are the lug hole centric and not hub centeric? I don't have a clue, but I know it makes a difference in balancing my trucks stock alloy rims and tires.
Al
ALWilson is offline   Reply With Quote
Old 11-22-2004, 08:26 PM   #9 (permalink)
VVT-i Owns's Avatar
I know they're important but I've given up on convincing them. They seem not to care...
- Vince
Old 11-23-2004, 08:11 AM   #10 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
You know, it's just one of those things. I wouldn't say that it's a Darwin thing, but some people just don't care/pay attention to things like this.
With these people, I just wonder what else in their life they don't take their time to find out all the facts about and see how they can improve themselves.
BenG is offline   Reply With Quote
Old 11-23-2004, 11:33 PM   #11 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Its pretty easy,
Your car's contact to the planet is through these four discs that spin.
These are your wheels and tires, agreed?
If they are not mounted as closely to center, they are out of round.
If so, they will force the axle to rise and fall if they are not dead center. Think of cams.
On matched wheel to hub mounts, they mount perfectly center because the wheel's center will match the flange on the hub. No chance for an out of round condition. The mating surface will be perfect.
However in our world, when we use a wheel that has a center larger than the hub fitment, there exists an opportunity for slop. Even self centering nuts cannot pull the wheel as close to the perfect center. Now multiply that by four wheels. Bouncy.
To correct this situation, we use an adapter, the hub centric ring.
See wheel dealer unless you know the exact measurements of wheel and hub.
It's not true that balancing is the only cause for the shakes. You can have four perfectly balanced tires but with one wheel not centered, no cure wobbles. Hub centrics do just that, make your mount centric to reduce wear and tear, discomfort, etc.
I would like a set but I do not want to expect more dealer sex to get them.
amerikim is offline   Reply With Quote
