To 88 LE, Turbo download? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-07-2004, 04:12 AM   #1 (permalink)
almc2242's Avatar
View almc2242's Photo Gallery
USA To 88 LE, Turbo download?
88 LE, I have the same turbo that you had on your 3SFE engine, before it blow. Airesearch, T3, .42/.48 40 Trim internal Wastegate. You said that this turbo is capable of 10 lbs. I already know that this is a with these engine. Since I'm just planning to do 6 to 7 lbs. How would you go about eliminating the internal Wastegate, and installing an external Wastegate on this specific turbo? I have the same problem you had, but your engine blow before you could change it. I don't want this to happen to me.
almc2242 is offline   Reply With Quote
Old 11-07-2004, 02:36 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: To 88 LE, Turbo download?
In your case, I don't think you can eliminate the internal wastegate since its part of the turbine housing.
I would leave it alone and not hook it up. IE: don't hook up a hose to the nipple on the wastegate actuator.
You need to cap off the nipple on the compressor housing or replace it with a 1/8" NPT plug.
Install the external wastegate on the turbo manifold. It needs to go before the turbo.
The outlet from the wastegate can either be blown off into the air or plumbed into the downpipe.
"Skoolin' the unlearned!"
Old 11-07-2004, 02:58 PM   #3 (permalink)
almc2242's Avatar
I was also advice to install the TurboXS Manuel Boost Control like this one. Also, to install a E-manage system. Any comment regarding this recommendation.
Old 11-07-2004, 07:58 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
You can use a boost controller if you want.
Just make sure that the wastegate has a spring that'll give you less then 6 - 7 psi. Then use the boost controller to crank up the boost till you get to 6 - 7 psi.
Old 11-08-2004, 04:00 AM   #5 (permalink)
almc2242's Avatar
Is their a guage that can be installed to monitor boost? Also, will the Greddy Emanage help?
Old 11-08-2004, 04:22 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
vacuum/boost gauge
Yes.
You need something to tune the fuel and ignition timing.
