Help with Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-09-2004, 02:07 PM   #1 (permalink)
View mdnt_7's Photo Gallery
Help with Brakes
My brake pedal is extremely hard on top, and seems not to depress no matter how hard you push on it. It's like pushing on a brick wall. Also, no matter how hard you press the brakes, the car has alot of difficulty in stopping. I changed the master cylinder, brake lines, and brake booster, and pads. I've must've bled the brakes a dozen times, removed/re-checked the master and booster to check for air/improper istallation, but the problem still exists.
Thanks!!!
mdnt_7 is offline   Reply With Quote
Old 11-09-2004, 04:12 PM   #2 (permalink)
Gameroom cash: $251510
iTrader Score: 6 reviews
View BDSL's Photo Gallery
Brake pistons might be seized.
BDSL is online now   Reply With Quote
Old 11-12-2004, 03:35 PM   #3 (permalink)
Thanks, I just checked the pistons, but they're okay. I'm running out of ideas...anyone?
Old 11-13-2004, 11:32 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Did you bleed the master cylinder before bleeding the brake lines? Did you adjust the brake booster push rod? Do you have ABS, 4 wheel disk, VSC?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-16-2004, 12:43 PM   #5 (permalink)
I did bleed the master and checked the booster pushrod before installation. The car is an AE86. 4-wheel disc, No ABS and no VSC. Thanks again.
Old 11-16-2004, 04:17 PM   #6 (permalink)
Possibly a vacuum restriction to the brake booster (e.g., clogged line, fitting, etc.). To test for this, pump your brakes, with the engine off, until there is no residual vacuum assist. Then, while pushing on the brake pedal, start the engine. The brake pedal should immediately go farther down as the vacuum assist (boost) kicks in. If, however, the pedal only slowly goes down, or doesn't go down at all, you should start looking for an obstruction in the vacuum line.
