warning bellls - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-15-2004, 10:09 AM   #1 (permalink)
View Flipgator's Photo Gallery
Angry warning bellls
I am trying to disable the alarm bell for keys in ingintion. I have disabled the door switch which took care of the bell but I also lost he interior light and the auto-off fefature on the headlghts.
There has to be a way to open the truck door and listen to the radio without loosing all the good functions.
Half the guys in the construction business use their truck raido. Every other truck (not Toyota) has had a module I removed to disable the bell.
Flipgator is offline   Reply With Quote
Old 11-15-2004, 10:12 AM   #2 (permalink)
View deekay140's Photo Gallery
what model and year???????
deekay140 is offline   Reply With Quote
Old 11-15-2004, 10:43 AM   #3 (permalink)
warning bells
Tocoma 2004, v6 extended cab
Old 11-15-2004, 10:56 AM   #4 (permalink)
if u look under the dash by the fuse panel, there should be a 22 pin plug below the fuses. unplug it and look at it from the side the wires go into it.. bottom row 8th wire from the left, should be light green/red wire .. cut that wire and it should disable the sensor that senses the key is in the ignition... be sure to leave enuf slack in case u have to refix the wire... sometimes the wire diagram doesnt show u that other circuits are using the same wire. good luck
