valve springs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-20-2004, 09:37 PM   #1 (permalink)
View sleepr's Photo Gallery
valve springs
dose any one know if there’s any difference between the valve springs from a 90 "fe" head and a 90 "ge" head besides the heads there found in?
you will see
sleepr is offline   Reply With Quote
Old 11-21-2004, 02:38 PM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
springs are stiffer for the 3s-gte vs 5s-fe
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 11-21-2004, 07:22 PM   #3 (permalink)
but are they the same size? could i put ge springs into a fe head? because look at this, its about what im looking for i want to shift at 8,500
http://www.atsracing.net/valve_springs.htm
wraith, should i keep posting or just im you because u ancer all my Q's
you will see
Old 11-21-2004, 08:15 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
your gonna need alot more than stiff valve springs to shift at 8.5k
Old 11-21-2004, 08:59 PM   #5 (permalink)
Immortal
View Kwanza's Photo Gallery
There will be no point in revving beyond the rev limiter unless you have some performance camshafts and have work done to the head. Even if you were to rev it on the stock stuff... the engine will make no additional power.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 11-21-2004, 09:03 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
why are you building a fe head instead of a ge head for rpm?
Old 11-21-2004, 09:39 PM   #7 (permalink)
im haveing a super hard time finding a ge head, and for needing more then stiff springs i have a block with:balanced crank arp main studs balanced and shot penned (2 times) rods with arp bolts on them and 8.5.1 ross racing pistons so i know the bottom end can take it. befor i started my build i made my mind up on how high i wanted to rev and how much power i wanted to get, im just geting parts for the head (and a head) togeather now. so if i cant find a ge head i still want to rev to 8.5
you will see
Old 11-21-2004, 09:56 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
AAHHHH finally somebody did their homework, but with the fe head, your power peak probably will happen well before 8.5k, the port to valve angle is just too sharp of a turn. If you put that kind of money into a short block, the head really should be able to flow enough air to feed it at hi rpm, I wouldnt put very much money into the fe head and just do a search for a ge head that with a good set of cams and a little port work will feed it nicely. try car-part.com or just search around, now the ge heads I have are the gen1 head with the huge intake ports and the tvis, I have heard that the later gen heads flow better, but I havent seen one of them yet or dont know how much better they do flow, but i have heard that the shims on top of the buckets tend to come loose at real hi rpms, so u might need a gen 2 or later with under bucket shims
Old 11-21-2004, 09:57 PM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
Do I see 8.5 cr pistons in your list? why so lo, turbo? whitch head are these cr figured with?
Old 11-21-2004, 10:08 PM   #10 (permalink)
yea there for a turbo, i went out and got a ihi turbo off of a 6.3 (i would post pics but i cant figgur out how ) the head for the cr is a 3sgte, would you happen to know if the 90 gte heads came with under bucket shims?
you will see
Old 11-21-2004, 10:10 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
do you have a email or do you have aol im by chance?
Old 11-21-2004, 10:17 PM   #12 (permalink)
yea i have a email its "Sean.McCarthy@mycm.cmcc.edu" and my aim name is "cascadedhart" but its not leting me on now ( )
you will see
Old 11-21-2004, 10:23 PM   #13 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
ok i added u to my aim list, i am fredk1037, im getting pretty tired and just might hit the sack in a bit, add me to your aim, nite
Old 11-21-2004, 10:30 PM   #14 (permalink)
cool, have a good one
you will see
