5efhe running lean - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-21-2004, 08:42 AM   #1 (permalink)
View dexter_5000's Photo Gallery
5efhe running lean
did an engine swap in my 92 paseo put in a 5efhe used the stock ecu, wiring harness, injectors, and throttle body. problem is my check engine light is coming with a code 25 which is lean air fuel mixture. i know the o2 is good, changed out the plugs for brand new 88 supercharged mr2 plugs. any ideas what could be causing this? i tried injector cleaner already too. should i just put in the larger injectors that came with the engine?
dexter_5000 is offline   Reply With Quote
