99 1mz-fe air/fuel hook-up - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-23-2004, 02:58 AM   #1 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
ok guys, i am almost fone with my gauge project, i will post pix in a couple days after i finish up my new razo shifter and clean up the car, i just added a TRD body kit too, but here is my question...
I am hooking up an air/fuel gauge and i have 3 wires, black neg. red positive and purple a/f sensor... I tapped into the blue wire coming off of the O2 sensor, right off the header, which i toyota told me would be the air/fuel sensor wire, but i get no reading on my gauge, there is also a white wire and two black ones, i tried to tap into the white and got no results either, so my question is this
1) am i going at the wrong wire splice all together?
2) could the gauge just be messed up, guy i bought it from said it was working before he sent it with 100% good feedback, if this is the case, how can i test that the gauge should work and it is not just me hooking things up wrong?
thanks for any response, i know a narrow band a/f is not accurate, i don't care, i have a vac gauge, volt, oil pressure and oil temp also hooked up which give me better feedback, i just needed this to fill my last pod and i got a good price
thanks for the response,
nate
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 11-24-2004, 12:47 AM   #2 (permalink)
Hamsterman's Avatar
anybody help out???
Old 11-24-2004, 12:51 AM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $109250
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I'llmove ya to the Hardcore Tech Forum, prolly get an answer there.
BLUEMEANIE is offline   Reply With Quote
Old 11-24-2004, 03:33 PM   #4 (permalink)
Hamsterman's Avatar
sounds good, somebody here should know
Old 11-24-2004, 04:26 PM   #5 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
I believe it should be Pink from the ECU. Somebody correct me if I'm wrong.
http://www.pbase.com/toycam/image/12448593/original
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 11-24-2004, 07:49 PM   #6 (permalink)
Hamsterman's Avatar
hmmm, never messed with the ecu before, i will check that out
thanks
Old 11-24-2004, 08:42 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395360
iTrader Score: 13 reviews
argghhh.....if you really can't figure it out, I'll check which wire I tapped again...I'm sure the 1st gen of 1mzs are pretty much the same....
HaHa
Old 11-26-2004, 01:07 AM   #8 (permalink)
Hamsterman's Avatar
i will look @ it friday or saturday, but did you tap your ecu wire or direct o2 wire pussies?
Old 11-26-2004, 01:33 AM   #9 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i got a 94-96 diagram that says its either red/blue or white. depending on front or rear bank. not sure which is which.
the way to really tell is its gonna be the one with an output of 0-5 volts when the car is running.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 11-26-2004, 03:27 PM   #10 (permalink)
TN Pussy Man
I tapped the ecu wire...
ratko originally told me which wire to tap, but then it ended up he told me the wrong one, and I remember having to try another one before I found the right one
if you really can't figure it out, then I'll check early next week to see which wire it is....it's just a hassle to remove the glove box to get to the ecu is all
HaHa
Old 11-26-2004, 04:09 PM   #11 (permalink)
Hamsterman's Avatar
don't worry about it, i am in my car now with my laptop so i am gonna go after it then i will post up if i get it thanks
Old 11-26-2004, 04:32 PM   #12 (permalink)
Hamsterman's Avatar
yeah this sucks, i just tapped the pink wire and nothing came, i think the gauge is messed up, i am gonna talk to teh guy i bought it from
thanks all
nate
Old 11-26-2004, 06:42 PM   #13 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
*Note* I've never worked on a 1mz-fe.
Hayes manual only shows one wire with pink on it for the entire ECU, a Pink w' black stripe. That's definately the wrong wire. It comes from the bank 1 sensor 2 O2 sensor, but is the HTR wire.
Bank 1 sensor 2 OXS is D26 - Black
Bank 1 sensor 1 OXR is B13 - White
btw I would think that a AAA or AA battery would move the gauge. (as long as the amperage is right)
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 11-26-2004, 06:49 PM   #14 (permalink)
Hamsterman's Avatar
so you think if i go
12v- red
ground-black
aa- purple, i should see some led movement? why would that be, just wondering
