Originally Posted by sloppybeak
I read where they burn plugs at an accelerated rate.
I haven't noticed those problems.
By the way,on hooking up the MSD to the factory ignitor on my "89 22r truck ignotor-do I then disable the ignitor(unplug it)?IN the end both the coil(with new blaster coil) and Ignitor shoould be disabled.
You need the ignitor, don't unplug it. The only thing you disable is the stock coil.
Use the 2 wires that goto the stock coil as a trigger for the MSD. You can also find these 2 wires on the ignitor, the stock coil and ignitor is connected together. So use the wires on the coil or ignitor, which one you use is up to you.
Do I need a Tach adaptor if my truck don't have a tach?What about a rev limiter.
I don't know if you need a tach adapter or not for your 22R. Best thing to do is contact MSD and ask them.
MSD 6AL has a rev limiter function.
http://msdignition.com/contact.htm
