MSD ignition systems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-23-2002, 10:19 AM   #1 (permalink)
View Meisner's Photo Gallery
I am about to instll an MSD 6A ignition system on my 96 Camry (4-cyl 5S-FE). After reading the wiring diagrams on the Camry and the MSD box, everything hooks up except the IGF signal coming back from the igniter to the ECU. The idea of this signal is to tell the ECU that the igniter is working.
How do I supply this signal back to the ECU when the MSD box is installed?
I posted this on TeamSC3, but haven't got a response.
Thanks,
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 12-01-2002, 09:03 PM   #2 (permalink)
View Rolla GT-S's Photo Gallery
have you tried msd tech? maybe you need an adapter of some sort, let me know how the msd works, thinking about one myself...
Forever 4A-GE
Rolla GT-S is offline   Reply With Quote
Old 01-07-2003, 01:40 PM   #3 (permalink)
I landed up installing the MSD boost retard module and the 8910EIS adapter. The setup works perfectly on my '96 turbo'd 5S-FE. The ECU has no problem with it.
Let me know if you need more info.
Steve
Old 01-08-2003, 12:41 AM   #4 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
actually u only need the 8910EIS for toyotas thats it...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 01-08-2003, 07:50 AM   #5 (permalink)
Huh? If you just installed the 8910EIS, there would be no change in your ignition system at all. It is just an adapter that goes along with another piece, like the 6BTM or one of the AL or SCI ignition amps.
The 8910EIS converts the ignition signal so the aftermarket ignition system can fire appropriately. Without it, the size of the ignition pulse is too small (as I viewed it on an oscilliscope) and the system won't fire at all.
The 8910EIS is only part of the aftermarket ign system.
Steve
Old 01-09-2003, 01:22 AM   #6 (permalink)
Blazin...
steve sorry man... i didnt post the rest i was just sayin about the upgrade to ignition modules.. im using MSD sci w/ blaster SS external coil with the 8910EIS i had so much probs not knowing about the 8910EIS i mean i known it but there was 2 kinds one for chevy's one for toyota.. and back then no diff only for chevys so i had so much freakin problems when the adaptor would heat up the engine shuts down!!! so it suckeD!!!!
but i got my proper adaptor like 3years ago and its been good since then but i still had it wired so i have a back up incase MSD dies again.. so its got a bypass wire so i can use my stock ignition system just with the blaster SS coil incase anything goes wrong.. kinda sucked gettin stuck in the middle of the road and the car not movin!!!!
Neoscepter
Old 01-09-2003, 05:55 AM   #7 (permalink)
I know what you mean...that's why when I wired in my 8910 unit, I took a wiring harness for the coil from an old Toyota motor and fabricated a new wiring harness that allowed me to keep all of the stock connectors on the original harness. Now if anything goes wrong, I can switch back to stock in about 15 seconds.
Steve
Old 01-09-2003, 12:10 PM   #8 (permalink)
Blazin...
nice a distrust in the msd as well huh?? hehehe... i did it on the cam and on my civic as well... but i havent had to switch them over yet.. except for the civic a few times... not sure why though.. but there are times where it just dies on me...
Neoscepter
Old 01-09-2003, 05:42 PM   #9 (permalink)
It wasn't so much I distrusted the MSD box as much as I didn't trust my work...also I really like keeping things as close to stock as possible.
Old 01-10-2003, 01:17 AM   #10 (permalink)
Blazin...
sure .. mr. meisner keeping his turbo 5sfe as close to stock!!! funny!!! heheheh
Neoscepter
