pro oil pump - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-28-2004, 03:57 PM   #1 (permalink)
View sleepr's Photo Gallery
pro oil pump
most of you know that you can raise oil psi by shimming the relief valve on the oil pump, I need to know fast how many psi can be gained from a .004 to .006 shims, I guess a better Q is, has anyone on here shimmed a oil pump before?
you will see
sleepr is offline   Reply With Quote
Old 11-28-2004, 05:36 PM   #2 (permalink)
View dexter_5000's Photo Gallery
there is such a thing as to much oil pressure you know thats why its there.
dexter_5000 is offline   Reply With Quote
Old 11-28-2004, 07:59 PM   #3 (permalink)
i know this, but whenyou would want more oil psi if your running looser clearances on the mains witch i am because you can get it to rev a little quicker
you will see
Old 11-29-2004, 08:58 AM   #4 (permalink)
Gameroom cash: $147537
Get a higher flow oil pump. Also make sure you seal everything really good. Toyota got metal gaskets for 5S-FE.
Old 11-29-2004, 12:09 PM   #5 (permalink)
i dont want i higher flow pump, i just want to get a little more psi out of the stock one by shimming it
you will see
Old 11-29-2004, 12:12 PM   #6 (permalink)
You'll need both. Get a Oil Pressure gauge if you shim it. Just to make sure you don't over pressure it.
Old 11-29-2004, 06:58 PM   #7 (permalink)
will do
you will see
Old 11-30-2004, 12:28 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
ok..........................
Old 11-30-2004, 12:51 PM   #9 (permalink)
Stop beating it, it may come back to life
Old 11-30-2004, 05:29 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
