Direct Injection - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 12-06-2004, 05:17 AM   #1 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
Direct Injection
What is it, how is it mechanically different from traditional fuel injection, and why isn't it stateside yet?
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 12-06-2004, 07:47 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
direct injection has the injector in the combustion chamber instead of somewhere ahead of the intake valve, I have heard of a couple cars that have it here
Old 12-06-2004, 09:39 AM   #3 (permalink)
View Squidward's Photo Gallery
VW has sold DI cars here in the 'States since '95. AKA VW's TDI. Turbodiesel Direct Injection.
BMW has had DI in a gasser here in the 'States for a few years, now.
The main difference between a conventional FI system and a DI system is that the injection pressures have to be a lot higher to be able to spray into a highly compressed air mixture. The DI system sprays fuel directly into the combustion chamber as opposed to spraying it into the intake tract, which is mixed with the air in the combustion chamber where it is compressed then burned.
The advantage of this system is that the fuel is much more precisely controlled, which means more power, less emissions (theoretically), and a longer lasting engine, since the raw fuel never gets a chance to touch the cylinder walls, which are coated in motor oil. On a conventional system the gasoline thins the motor oil on the cylinder walls.
Squidward is offline   Reply With Quote
Old 12-06-2004, 02:37 PM   #4 (permalink)
View gcs118's Photo Gallery
How in a DI system does the fuel not touch the cylinder walls? Also, would the fuel injectors have locations more like the spark plugs in DI rather than the traditional fuel rail/intake manifold location?
gcs118 is offline   Reply With Quote
Old 12-06-2004, 09:23 PM   #5 (permalink)
In a conventional setup the fuel is mixed with the air as it enters the combustion chamber and this allows the fuel to make contact with all surfaces that it can come into contact with. With a DI system the fuel is sprayed in just before the spark plug fires so the piston is approaching TDC when it starts to spray and the spark plug fires almost right after that, burning the fuel before it even has had a chance to hit the top of the piston.
Old 12-09-2004, 08:37 PM   #6 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
not much but there is a little pic of the setup.
http://www.boschusa.com/AutoOrigEqui...rectInjection/
Vw is using this setup in europe right now. Not being used here in the US as far as I know.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 12-14-2004, 05:28 AM   #7 (permalink)
View b1gb3n's Photo Gallery
in reality, DI uses less fuel when idling. other than that, it doesnt produce more power or fuel efficient when car is running.
that is y not all cars use DI system.
b1gb3n is offline   Reply With Quote
Old 12-14-2004, 12:01 PM   #8 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Honda's explanation is nice. Long though.
http://world.honda.com/HDTV/news/2003-4031127a/
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
