probably the best thing to do is go over and pop the hood and have him start it up cold, listen for lots of noises before the oil filter fills up, and continuing motor noise after it fills, look for lite smoke out the tailpipe and nasty coolant, a goop covered oil filter and black thick oil usually is a bad sign too. Its kinda hard to tell from here how the motor is doing, so just check it out and it might be a good idea downtime wise to get a reman motor or a lo miles one to pop in when you need to, these s motors are usually very durable, 500k miles have been recorded on them, but it all depends how the motor has been cared for, and change the timing belts at about 60k!!
