HELLLP!!! engine cuts out at 2100rpms - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-07-2005, 09:41 AM   #1 (permalink)
View busybeezturbo's Photo Gallery
Unhappy HELLLP!!! engine cuts out at 2100rpms
My engine (89 7mgte) cuts out ay 2100rpms and starts running again at 1400rpms hard to start takes 6-8 tries before starting.
busybeezturbo is offline   Reply With Quote
Old 01-07-2005, 03:32 PM   #2 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Do a full tune up. Timing could be off.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-07-2005, 06:54 PM   #3 (permalink)
LOVE TO LICK
ILLICITDRIVER's Avatar
View ILLICITDRIVER's Photo Gallery
timing is controlled by cam sensor. might want to check your cam position sensor and as userlain said....complete tune-up (plugs, wires, oil change, throttle body cleaning)
also, check the connection to your coil packs, might be loose due to time.
ILLICITDRIVER is offline   Reply With Quote
Old 01-07-2005, 07:40 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
check engine lite on?
Old 01-08-2005, 09:42 PM   #5 (permalink)
yes check eng.light is on I did the throttle body cleaning that is when problem started. have new platinum plugs just changed after prob.started
Old 01-08-2005, 09:45 PM   #6 (permalink)
could this be o2 sensor???
Old 01-08-2005, 09:54 PM   #7 (permalink)
heLLLPP!! my eng.is cutting out
I noticed that when I unplug MAF the eng. revs to 2800rpms before cutting out to 1400rpms
Old 01-18-2005, 04:17 AM   #8 (permalink)
View H.T.D.T's Photo Gallery
Htdt
Please check the induction tube most likely there is a split in the tube it's a intermittent problem
H.T.D.T is offline   Reply With Quote
Old 01-18-2005, 09:56 AM   #9 (permalink)
Ihave taken off all intercooling piping and other hoses and checked them for cracks and holes.didnt find any.
Old 01-25-2005, 10:18 PM   #10 (permalink)
Ran code check and came up with o2 sensor code,AFM code and Intake Air Temp.code will try changing o2 and AFM (black box). B
Old 01-25-2005, 10:23 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
can you give us more detailed meanings of the codes?
Old 01-25-2005, 10:59 PM   #12 (permalink)
do you need numbers #21 o2 sensor code, #24 Intake Air Temp,#31 Air flow meter signal. Is that what you wanted to know?
Old 01-25-2005, 11:01 PM   #13 (permalink)
The car was cutting out at 2100rpms when I unpluged the AFM car started cutting out at 2800rpms.
Old 01-25-2005, 11:04 PM   #14 (permalink)
View anuthaCamry's Photo Gallery
wow, it sounds like a loose or disconnected cable. Or a blown ignitor and/or distributer. use a timing light
anuthaCamry is offline   Reply With Quote
Old 01-25-2005, 11:07 PM   #15 (permalink)
I have trouble code chart for MK1,MK2, MK3,MK4 Supras.you have codes you need to check? If so add to post and I will check them. B
