Broken bolt pulling techniques. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-09-2005, 12:22 AM   #1 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Here's what happened. I was taking my car apart to get the dumb turbo out.... and there was a series of bolt snappings along the way. The one I'm concerned about is the one that holds my heat sheild to my exhaust manifold. It broke of flush with the manifold.... so there is no way to pry, twist... etc. Anyone have any tips of taking bolts out that are broken in this manner? Thanks!
PS. I'd like to keep drilling it out as a last resort.
Old 01-09-2005, 01:06 AM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
If the head of the bolt snapped off (only the shaft is left) and it's not rusted in; there won't be any tension to keep it from spinning.
Take a small, stiff wire brush (like from a dremel), apply pressure and spin it out.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-09-2005, 01:10 AM   #3 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
if its stuck in there, youll have to drill it out, then re-tap it to a bigger size, but you could just leave it off, if its anything like mine, there are like 20bolts on that thing, Im a firm believer in the 2/3's rule
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 01-09-2005, 01:14 AM   #4 (permalink)
Toysrme's Avatar
Cool
^ Eh I'm not. *note* I have no exerpaince with that motor, but the above is why the gasket for my buddies 400hp awd celica blew the entire legnth of the manifold!!!
(Seriously, you could see the exhaust blowing out of the entire length of the gasket and when you tuened it off you would see the little bit of fuel/exhaust mix run out of it)
Now with Turbo!
Old 01-09-2005, 01:28 AM   #5 (permalink)
Tommy's Avatar
well, thats a manifold, we're talking about a heat sheild, not exactly critical for it to have all its bolts like a mainfold.
My garage
Old 01-09-2005, 02:55 AM   #6 (permalink)
Toysrme's Avatar
Cool
My bad I mis-read that. I thought he meant the manifold itself!
Eh, it's a heat shield so who cars. Use the 2/3 rule by all means!
Now with Turbo!
Old 01-09-2005, 03:46 AM   #7 (permalink)
Piddy's Avatar
Its right on the edge tho.... i guess i'll leave it unless it starts making an annoying noise.
Old 01-09-2005, 07:40 AM   #8 (permalink)
View dexter_5000's Photo Gallery
you can get an a craftsmen drill drill out. if you can get in there wth it.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 01-09-2005, 11:17 AM   #9 (permalink)
View Deep's Photo Gallery
Grab an easy out for a couple of bucks.
Deep is offline   Reply With Quote
Old 01-10-2005, 10:30 AM   #10 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
There are also extractor sets that consist of a drill bit, a bit guide, and a shaft. You drill a hole that is smaller than the bolt shaft. Then you hammer a splined shaft into the hole. There is a sleave that slides over the splined shaft and fits a wrench. Simply turn and out it comes. I've got a set and they work rather nice. No thread damage.
TcmaBoy is offline   Reply With Quote
Old 01-10-2005, 01:55 PM   #11 (permalink)
View shwartz be with's Photo Gallery
broken bolt
I've always been told to heat it with a torch, then pound a phillips screwdriver into the end of it. After you pull the phillips out, pour cold water on the bolt area to make it contract quicker than it would if you let it cool on it's own. This will usually break any rust or corrosion holding the bolt in place. Then hopefully it's loose enough that you can put the phillips back into the dent you made in the head of the bolt and just turn it out.
shwartz be with is offline   Reply With Quote
Old 01-10-2005, 04:23 PM   #12 (permalink)
Noob
aosmith's Avatar
View aosmith's Photo Gallery
go to the hardware thing and they have a squarish thing that goes in a drill, you drill a small hole shove it in and itll twist the bolt right out
2000 A6 2.8 (the nice car)
chipped (tranny+engine) rear+front strobes, 12" CVR sub
1986 Toyota mr2 (the soon to be race car)
Currently: stripped, engine torn down
aosmith is offline   Reply With Quote
