I was wondering if the 3SFE engine needs a Fuel Rail. Since I'm changing fuel injectors from stock to 23250-46050 360cc for a turbo charge setup. BTW, this is for a 5SFE engine. Will it fit my 3SFE?
It's a hollow piece of metal the fuel send hose plugs in to.
There are cut-out's along it's legnth for injectors to plug into. Generally the FPR will thread into the fuel rail opposite the fuel send, or after the last injector if their are multiple rails.
It's basically how injectors get fuel and stay mounted. The bottom of the injectors push into the manifold/head, the top is held in the same way via the fuel rail.
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
What's your reasoning for adding more fuel = more power? More fuel + no increase in air = no power. You'll be hard pressed to max out the flow of the stock fuel rail for any injector you use.
But no, it won't add more fuel, the injectors will still be opening at the same duty cycle with the same amount of pressure.
You can use the FPR to tune with, have my stock unit boosted a little bit to prevent a lean condition at wide open throttle, shifts just under the fuel cut, is faster now.
The problem with upping the fuel pressure is that you can only go one way, richer, and when you've made it too rich you have to get another regulator, or lean the mixture some other way.
I used a large drift and a small ball/peen hammer to tap on the back of the regulator until it ran the way I wanted.I made adjustments while using the stock air filter with no ducting before the filter, then when I'd gone just a little too far on the mixture, I installed a foam sock(motorcycle)type air filter, and now it's just right.
The lower rpms will self tune again using feedback from the O2 sensor.
No, it's correct. Fuel pumps are positive displacement pumps. More pressure = less flow (gph or lph).
-Tim
More fuel pressure will lower the maximum amount of fuel the fuel pump can flow. That's not the issue here. If there is headroom (and there will be if he goes with a Walbro pump), there will still be extra flow past the regulator.
Extra fuel pressure at the injectors will flow more fuel for a given injector pulse time, which is my point.
-Charlie
