Okay, so I've got this guy who wants to get about 250 hp out of his 4EFTE. The engine is a stock turbocharged 1.3 liter making something like 145 hp. I figure that another 100hp is about a 66% increase in power, needing another 9 psi of boost over stock which I believe is 7 psi or so.
So, I assuming that we need around 15 psi total. Now, a 1.3 engine running at 7500 rpm (stock redline) and assuming an 85% volumetric efficiency (probably a little better than that), I figure that the engine consumes 145 CFM:
79 x 7500 x 0.5 x .85 / 1728 = 145 cfm
Now, if we're running 15 psi, the pressure ratio is a touch higher than 2.0. So, 2.0 x 145 = 290 which is the cfm under boost.
We have to convert the cfm to lbs of air per minute for most compressor maps, so going with a temp of 85*, 290 x .073 (weight of air at that temp and sea level) is about 21 lbs of air per minute.
So, looking at a T3 Turbo with a 50 trim, 21 lbs of air per minute and 2.0 pressure ratio is sitting right around 73%. On the other side of the map, assuming boost is made at 50% of max RPM (which is about 3750), then 10 lbs per minute is at 70%. Now drawing the line down to 20% of max airflow, around 4.5 lbs/min, it goes right along the 70% line and stays well inside the surge limit.
So it should look like this:
So, is this a good turbo and are my calculations correct? Or am I wrong somewhere? Is there a better turbo that you would suggest?
*Edit*
This GT22 looks pretty good as well, in 60 trim:
