you cant change the head on a FE to a GE..wont work sorry its been discused before, valve clearence is off, youll kill everything if you do it, these saddly arent like honda engines
nice manifold and turbo though...good luck with that.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Somehow people are able to use 3S-GE head on 5S-FE block without valve clearance problem. I'll think the 3S-FE is the same.
I believe there is a write up for 5S-GTE build up in the sticky. Also there is a few 5S-GTE running in Camry and Celica, even Corolla. The only thing is only a certain gen GE head fit a certain gen 5S block. I believe it is late GE head and early 5S block. This doesn't apply to 4A-FE to 4A-GE convertion. Only work with 5S-FE to 5S-GE convertion.
Those people have fully custome engine internals - the GE or GTE head does not directly swap over to a motor with FE internals. Early S motors have the same water/oil passeges, later 5s motors are not compatible (and possibly later 3s motors, I'm not sure...). Also, as 88LE said, you have to be careful when mixing cranks, block, rods, pistons, etc... They don't just automatically bolt up. Also, remember that everybody that has a hybrid motor is also probably running a standalone ECU.
It CAN be done, but its not nearly as simple as just changing the head.
-Charlie
The one I know that runs great is all stock 3S-GTE top and 5S-FE bottom. You can't mix piston and crank, they just won't fit. ECU is another thing, most like stock 3S-GTE or 3S-GE ECU will work. No sensor on the block, just the head. Of course you'll need something to tune the fuel a bit.
I believe Wraith have a write up with 5S-GTE build. I think its in Carmy forum.
If you are truly talking about Justin's (Wraith's) car, you are sorely mistaken about the stock 5s-fe bottom. The internals are fully re-worked. The block itself is mostly original.
Like I said, the pistons (at least) need to be changed (from the thread):
"°87.5 mm Forged pistons( basically a 5S-FE rod but with 3S-GTE top piston design) with 8.8:1CR and 5S-FE wrist pin hieght(which is stock on USspec. and J-spec. 2nd gen 3S-GTE), but you can run any compression you want. "
-Charlie
I'm not talking about his engine. The one I know was in a Corolla. Stock everything. No custom piston or any internal parts. The guy's dad is Toyota mechanic. I believe they're fitting that engine in a MR2 now.
When I was looking for a head for my 5S, his dad offer me a 3S-GE head and say just bolt it on.
I think with the bigger valve angle on GE head, the chamber is higher and the valve has more horizontal travel and less vertical travel then the FE head. The FE piston is caved and will have lower CR with a GE head which is better for turbo.
yes, the fe piston is dished because the chaimber in the fe head is alot smaller than the one in the ge head because the val;ves in the fe head are more straight up and down whitch makes the chaimber flatter. Yes the fe piston DESIGN is better for a turbo, but it is not strong enough to take much of a pounding, your better off getting pistons for a 3sgte and good rods or at least the rods from the gte or ge with good bolts in them
