T-25 on a 5sfe? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-20-2005, 03:07 PM   #1 (permalink)
trebor_9513's Avatar
View trebor_9513's Photo Gallery
T-25 on a 5sfe?
I have come across a Garret T-25 turbo. Has minor in-play. The thought of putting this on my 5sfe has crossed my mind. But, this idea is basically a starter idea. If it would work, it would eventually be upgraded. I have read that the T-25 has been used for the 4a and 7a motors, would it be beneficial to a 5s?
Plan: start as a 5sfte, ( At a low boost of 4-6 lbs no higher )
aquire more parts,
build into a 5sgte!!!
These are big plans. But, I want to do it in steps.
So, would the T-25 be a good starting turbo? Should I keep on for the CT-26 or larger? I know if I wait for much a larger turbo I need to upgrade all at once to have it functioning healthy.
trebor_9513 is offline   Reply With Quote
Old 01-22-2005, 12:37 PM   #2 (permalink)
Guess whos back
View CamryWhat?'s Photo Gallery
well here is the thing....you have to build a custom manifold.....as for the ct26 you have a manifold right there that mounts right up to the camry and saves you about 300bux... as for t25...Its is a much smaller turbo then the ct26....the ct26 flow more CFM's then the t25 also...And it spools up about the same rmp (2900) so more CFM's and a same spool.....But it up to you... i am going ct26
2000 VW Golf: CAI Exhaust 18's Koni/Nuespeed
92 Camry- No motor Stock and Stock!
CamryWhat? is offline   Reply With Quote
Old 01-22-2005, 01:58 PM   #3 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
I don't mean to be an ass, but you can't have animation in your sig.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-22-2005, 02:39 PM   #4 (permalink)
Guess whos back
its gone
Old 01-22-2005, 03:17 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Actually the T25 will spool up alot quicker than a CT26 on a 5S_FE but will top out at about 4800rpm then your just trying to squeeze all that exhaust into a smaller housing... Totally mis-matched for 5s-fe from my personal opinion
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 01-22-2005, 04:31 PM   #6 (permalink)
Thanks for the info. I personally am not very knowlegible of turbo size and capacities. It was just a shot in the dark. So, I'll just do what I was originally going to do, Clean up and sell on Ebay.
Old 01-23-2005, 10:44 AM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
no problem ... Thats what the hardcore forum is for...
MySpace:
