After getting all the parts through
here, since overall, they had the cheapest prices, I spent about 4 hours replacing the entire front and rear rotors and pads. The rotors were Brembo-made for OEM and the pads were PBR semi-metallic.
Original front:
Use a coat hanger to suspend the caliper, so the brake line won't be tugged on:
Once the pads and torque plates are removed, the front looks like this:
New front:
Original rear:
The rear stripped should look like this, use some brake cleaner to spray it down:
New rear:
To remove the rotors from the axle hub, use two long enough 10mm machine screws to back them out:
If the rear rotors won't release, turn the parking brake adjuster wheel clockwise:
Note: The front calipers are removed by taking out 2 bolts. The rear calipers are taken out by removing the lower bolt, pivot, and slide out since the top isn't removable, as it's stuck to the torque plate. Remove the bolt securing the brake line to the strut for adjustability.
Thanks to SilverStreak for some hints, as originally, I tried to use a hammer and 3/8" extension to loosen up the original rotors, as they were stuck. Luckily, an extra car and a run to the local hardware store, I didn't waste too much time trying my "caveman" method.
I haven't had time to drive out and try them yet, only backed in and out of the garage, as we're getting up to 12 inches of snow here.
