swapping heads?? 4af off 4afi engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Closed Thread
Old 01-29-2005, 03:29 PM   #1 (permalink)
View trailblazintoy's Photo Gallery
Lightbulb swapping heads?? 4af off 4afi engine?
just bought a 89 corolla with a blown motor. i found one & heard it run, but it is fuel injected. i thought i could just drop it in & go, but now i'm thinking i may have to swap heads, since the car is set up for carburation, not fuel injection. is there anyway i could plug the fuel injection holes, and swap my intake manifold and use an inline fuel pump? i'm also having to replace the flywheel off the good motor & put my old torque convertor & flywheel on it. any other problems i may run into? is it hard to change the wiring harness for fuel injection? i'd really like to avoid changing the head if possible. any help would be appreciated. thanks, linda
trailblazintoy is offline
Old 01-29-2005, 09:25 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
unless you have the entire car that has efi at your disposal, I would just plug the injector holes and use your intake and all, your going to need the flywheel bolts for the flywheel your going to use too and keep your distributor too
fredk is offline
Old 01-30-2005, 04:36 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Please don't cross post.
4af efi to carb head swap???
8. No double-post or cross-post is allowed.
http://www.toyotanation.com/forum/t1779.html
"Skoolin' the unlearned!"
88 LE is offline
Closed Thread
