No Fuel No Start - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Closed Thread
Old 02-01-2005, 01:00 AM   #1 (permalink)
View pepecrower's Photo Gallery
Unhappy No Fuel No Start
Hello fellas i need your help here with a fuel system problem that im trying to figure out. This is a 86 Toyota 4Runner with 22RE EFI engine stock. This Toy was running before but it was time for a rebuilt. This is where Iam at Ive checked the Ignition system and its all good, I did a compreesion test and read all cylinders above 100psi{good}, Next I checked fuel system what i found to be wrong, -- I grabbed a spray bottle with fuel and sprayed some into the throttle body Car will start until the fuel that i sprayed was gone. So I took off top intake "again" to check the fuel system right. It has a new filter on it, I check for voltage on each injector plugs;They all have signal voltage, There is plenty of fuel in in the fuel rails including the "cold start" line injector. There only place I didnt get any signal voltage was from the cold start injector plug, But i wasnt sure if it works only when you crank the engine. So fellas Whats happening here Im pretty positive is not the injectors if one was bad engine will still start Could a fuel pressure regulator cause this kind of problem?? Any help will be great thanks PEPE
pepecrower is offline
Old 02-01-2005, 03:17 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Cross posting.
No fue No start Help Please
"Skoolin' the unlearned!"
88 LE is offline
Closed Thread
