Tire Pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-12-2002, 03:20 AM   #1 (permalink)
View Mr.Incognito's Photo Gallery
Anyone know what pressure my 225/45/17 kuhmo supra 712's should be at on a 99 camry 4 cyl?
Mr.Incognito is offline   Reply With Quote
Old 07-12-2002, 08:33 AM   #2 (permalink)
View Naito's Photo Gallery
check your door jamb
Naito is offline   Reply With Quote
Old 07-12-2002, 08:35 AM   #3 (permalink)
no it doesn't matter that ur tires are aftermarket and differnt from your stock ones....check you door jamb! (should be written there...if not check ur owners manual)
Old 07-12-2002, 04:15 PM   #4 (permalink)
rayray's Avatar
View rayray's Photo Gallery
actually, i think the recommended tire pressure is on the side of the tire itself.. in PSI (pounds per square inch).
the owners manual will show the recommended pressure for the stock tires not aftermarket ones. usually, the lower the profile the higher the pressure.
-rayray
_________________
1992 Camry LE 5S-FE
Calgary
<font size=-1>[ This Message was edited by: rayray on 2002-07-12 17:17 ]</font>
rayray is offline   Reply With Quote
Old 07-12-2002, 11:22 PM   #5 (permalink)
no, that's a common mistake....the number on the side of the tire is the MAXIMUM pressure the tire can handle....filling it to that will give you uneven tire wear (the centre of the tread will wear out first) and it's quite dangerous...ALWAYS follow the door jamb number...
Old 07-12-2002, 11:32 PM   #6 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $697365
iTrader Score: 6 reviews
View EKam's Photo Gallery
And that answer is correct.
But that doesn't apply to tires that's not the same size as stock.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
Old 07-13-2002, 01:02 AM   #7 (permalink)
The terrorist
View Xenon's Photo Gallery
I always thought tire pressure was tire pressure. No matter what tire you have on what profile you always have to follow the number of psi's specified for the vehicle..
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 07-13-2002, 01:09 AM   #8 (permalink)
rayray's Avatar
so exactly what is the guideline for tires that are bigger than stock?
-rayray
Old 07-13-2002, 01:25 AM   #9 (permalink)
The terrorist
I didn't understand the question!! But I probably don't know the answer to it anyways..
Old 07-13-2002, 09:29 AM   #10 (permalink)
View bondobondo's Photo Gallery
this is a hugely debated subject, from ppl saying that the door jam number is artifically low to start with, because they rate the pressure for a tire that is going hiway bound for its entire life and they use that rating.
now when a tire is on the hiway, it is HOT, very hot, and the vehicle manufactures have to use a safety of margin in that air expands when it is hot, so they have to estimate a safe operable pressure. they have ratings like 28-31psi usually.
now if you drive in the city most of the time, your tire will never reach such a hot temperature, so a high psi rating can be used, around 31-34psi
if you are at teh track the tire is much hotter than what it would normally be, hence an even lower pressure than stock to compensate for the high temperature: 24-27 psi
vehicle manufactures also calculate load bearing on each wheeel and they have to ensure that there is suffecient psi in the tire to carry these loads, for a passenger car they are usually at the maximum, of 1 driver and 3 passengers.
no matter what profile tire, a &quot;safe&quot; operating pressure would be around 30-33psi, 35 at the highest. as any higher would make the center bead of the tread wear out prematurely, and usually at the higher pressure, the tire runns cooler, performs better (in the dry definately, in the wet, it is marginal) provides better feedback to the driver, and corners sharper.
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
bondobondo is offline   Reply With Quote
Old 07-13-2002, 09:49 AM   #11 (permalink)
EKam's Avatar
I hope you're kidding, cuz last time at auto-x I had to pump it up to 41 psi and everybody increase their tire pressure, not lowering it.
Old 07-13-2002, 09:50 AM   #12 (permalink)
EKam's Avatar
-rayray
Simple, you follow the tire manufacturer's recommended tire pressure for the specific size! :grin:
Old 07-13-2002, 12:50 PM   #13 (permalink)
at an autocross it is different, cuz you get 1 run, yes, ONE RUN.
and then your tires cool for like 30 mins until your next run.
if you drive decent, that run lasts for under 1 minute.
if you go to a lapping event, or something where your tires are ALWAYS turning, and you are going at speeds alot higher than 60km/h in 2nd gear, your tires DON&quot;T get a chance to cool, even in the pits for 20 mins won't cool them down.
you are cornering at higher speeds, braking at higher speeds, these are all sever demands placed on a tire.
compared to taht 1 minute of fame on an autocross, a decent car can lap around for a good 10-15 mins, until brakes/engine have to cool.
so no, i am NOT kidding.
_________________
æ92.FF.pilot
<font size=-1>[ This Message was edited by: trueno92 on 2002-07-13 13:51 ]</font>
Old 07-13-2002, 04:39 PM   #14 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
-rayray
_________________
1992 Camry LE 5S-FE
Calgary
u do that if u want to blow up ur tires
boroEF is offline   Reply With Quote
Old 07-13-2002, 11:41 PM   #15 (permalink)
Tailgating You
View TRD 4Runner's Photo Gallery
For off roading...drop the pressure to 7 psi :grin:
The tires on the 4Runner can handle 44psi...filling it up to that made it feel like driving a bus on stilts.
Don't know, don't care, everyone is entitled to my opinion.
Lowering your car is hazardous to your health -Toyota 4Runner
TRD 4Runner is offline   Reply With Quote
