Air intake for my 2wd Toy truck - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-12-2002, 09:50 AM   #1 (permalink)
View MedicMoose's Photo Gallery
Can I get a performance air intake for my pickup with the 2.4 litre engine that replaces the entire factory air cleaner box?? What about the mass air flow sensor...what happens if that is removed??
MedicMoose is offline   Reply With Quote
Old 07-12-2002, 11:15 PM   #2 (permalink)
View Deep's Photo Gallery
The mass airflow sensor meters the amout of air that goes into your intake manifold. If its not there, the ecu can't make a good air/fuel calculation and your motor will run like sh*t.
Deep is offline   Reply With Quote
Old 07-14-2002, 10:29 PM   #3 (permalink)
94 Rolla Guy
Guest
Posts: n/a
View 94 Rolla Guy's Photo Gallery
its unfortunate we drive toyota's sometimes! unlike Honda guys we can't just go buy all the go-fast goodies. My motto if u can't buy one make one! measure your throttle body....then go to home depot and buy some pvc or abs pipe thats just a bit bigger and a whole bunch of fittings and make one! top it off with a filter and connect it to the motor with some sort of rubber coupler. cost less too. don't forget the MAP sensor look how its mounted in the OEM unit and get it mounted as close as you can to the original
Old 06-30-2005, 11:40 PM   #4 (permalink)
Street Racer
View BlkSrx's Photo Gallery
some pvc or abs pipe, are you crazy. Just get Lc Engineering intake and Bored throttle body, and move three teeth on the MAF. there more power. its a clean look to under the hood
BlkSrx is offline   Reply With Quote
Old 07-01-2005, 01:39 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
tried K&N?
they might have a FMIC kit for your car.
terrastrife is offline   Reply With Quote
