location of engine code stamping - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Closed Thread
Old 02-01-2005, 12:41 PM   #1 (permalink)
View fleetwood dicki's Photo Gallery
Canada timing marks
ive got a standard 91 corolla 4dr with a 4a fe engine. im trying to figure out the timing marks. first i found the cam gear marks, one line and a dot. do they line up with the valve cover to gasket surface and which one for base timing? also which position whould to dist rotor be in if tdc on 1 in compression. i found the leads on the cap all messed up. i assume as with other 4 cyl the firing order will be:1,3,4,2 clockwise facing top of dist cap.
help please
fleetwood dicki is offline
Old 02-02-2005, 02:57 PM   #2 (permalink)
4afe basic specs
ive got a standard 91 corolla 4dr with a 4a fe engine. im trying to figure out the timing marks. first i found the cam gear marks, one line and a dot. do they line up with the valve cover to gasket surface and which one for base timing? also which position whould to dist rotor be in if tdc on 1 in compression. i found the leads on the cap all messed up. i assume as with other 4 cyl the firing order will be:1,3,4,2 anti-clockwise facing top of dist cap.
one last thing, whats the comp gunna be? i did a test and it read 1:120psi,2:60psi,3:60psi,4:160psi......160???
Old 02-02-2005, 05:35 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
dont matter aboput the timing belt now, the 2 low cylinders next to each other is a pretty good indication of a bad head gasket, 160 is about right
fredk is offline
Old 02-02-2005, 05:42 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
get the tbelt off it, pull number one plug and get the piston all the way up, now pop the dist cap and it should turn ccw, there is probably a little number 1 on the cap by a wire tower, simply align the rotor with this tower and you should see some kind of mark aligning probably at 12 o clock on the cam gear, probably a line, put the tbelt back on and put the cap back on, leave the motor on the jack and be shure its not in gear and start it up, see if it sounds and feels right, if it does, put it back together
fredk is offline
Old 02-03-2005, 02:14 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
1. Please don't cross and/or double post.
2. http://www.toyotanation.com/forum/t1779.html
Refer to rule #8
3. http://www.toyotanation.com/forum/se...r&userid=25279
"Skoolin' the unlearned!"
88 LE is offline
Closed Thread
