Cupping/Tire wear
For my 2000 Corolla
My tires wear unevenly, the front more than the rear. The outside edges wear more than
anything else, and the insides slightly.
What should I do to fix the problem? I had a 4 wheel alignment done about 2 months ago, but I am not sure if I had this problem before or after the alignment. The alignment was not done by Toyota, however I trust the shop that did the work.
I have been told the alignment is only part of the story in this case. I have also been informed that if my tie rods or ball-joints are off that I would also have this problem.
Toyota insists I should get an alignment from them and then they will also inspect the ball-joints and tie rods.
My car had moderate front end damage about two years ago. It wasn't enough to damage anything under the car or structurally, just asthetically (bumper, hood, panels etc).
PLEASE advise.... Toyota's alignment is about $100, plus $85 to check tie-rods/ball joints. Toyota states the tie-rod/ball joint inspection isn't useful if they can't also check the alignment. They seem overly convinced that their alignment will fix everything. I know a lot of folks HATE toyota, but the fact is, while their prices may suck, I trust the work they do.
