the way u're describing is a clutch-drop start and powershifting...
IMO, clutch-drop is the fastest way to start, but powershifting isn't the fastest way to shift becasue every time ur tires are chirping, they're slipping, which means there's power going to waste.
I rev slightly (no tach so don't know where exactly, probably around 3500rpm), drop the clutch and then floor it as I'm dropping it so the engine won't lug, if it does then I've dropped the clutch too fast or didn't rev high enough. Then I just shift as I usually do, redlining it every time tho and yanking the shifter faster than usual is all. Every shift the clutch is released and reengaged as fast as possible, without chirping the tires, which is getting increasingly difficult thanks to my damn tires having no freaking tread left.
