So this Saturday my club did a dyno day and I decided to throw my 2001 5-speed Corolla on the Dyno Jet for a baseline run. My only mod to the engine is an EL Prototypes Cold air Intake. The car has about 65,000 miles (~104,000 kilometers) on it.
Now most stock 5-speed 1ZZ-FE Corollas put down about 110 WHP and equal Torque. I have seen enough dynos to know this. I expected to see at least that if not a couple more horses from the ELP CAI. A bunch of people went before me and put up the expected numbers for their mods with no surprises.
Well They strap my car on the dyno and when they floor it for the first pull, the A/F ratio shoots up from the 14 or so that it was at during idle to almost 17!! The guy running the machine is like "Whoa, whoa this thing is running really lean!" So the guy in the car backs off. He says sometimes this happens on the first pull and lets try again and see if it richens up. So they rev it up again and again my A/F shoots up with the revs so that it is at 16-17 at redline.
So they decide they don't want to run it hard anymore and take it off the dyno. It put down 98 lb-ft of Torque and 88 HP
, obviously because it is not being supplied with enough fuel up top right where the power band is. I have a pretty good idea that either 1, there is a problem with my fuel delivery, like a clogged fuel filter, or 2, my Mass air flow sensor is not reading any additional air past a certain RPM so it stops telling the fuel system to add fuel even though more air is comming through.
I figure I can try switching back to my stock air box, putting some fuel system cleaner in, and changing out the fuel filter, but what is an inexpensive way to see if my A/F is OK?? I would never have known this without the wideband O2 sensor at the performance shop, so how can I check A/F without one?
Thanks
Chris
