The relays were $10 each with the wiring harness. You need to tap into the parking light in order to hook up the relay between the signal and the parking light.
Now if you don't mind it if the signla flashes quicker than it should. You're OK. But if you do mind then you'd have to add a another socket behind the bumper and add a bulb there (That will work as your regular signal). It's not very easy said, I'd have to explain it to you and give you the colour coding. If you need the Relays, tell me and I'll pick them up from the shop today and I'll keep them for you. We just got an order of themfor the shop.
I'll help you with it if you need. The only annoying thing was the extra socket/bulb combination to keep the signal flashing rate the same.
You can also call me on my cell or at work, you have both numbers from what I remember!
My sexy AE92 http://members.cardomain.com/ababan
