oil press
Nick's right, the problem with almost all oem gauges is that they're not calibrated. Oil pressure is a perfect example since it only shows relative pressure, ie: low-medium-high and not 75-125-150psi. The Autometer's don't cost a lot, I think they run under 100$. I'm putting in aftermarket oil pressure gauge into my cars as soon as I can ship the block adaptor (it's mechanical), let me know if you want to check mine out or if you need any help Norm.
AW11 / AE86 / AE100
