An intercooler. Most likely running something like 6-8 PSI I'm guessing? That's a relatively safe range. He won't know how much HP and torque until he gets it installed and dyno'd. You're going to need some type of exhaust manifold, blow off valve, wastegate if you don't already have one. I think you need water cooling lines too. Good luck!
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
