Ignore the marks on the belt. As long as the 2 cam gears (sprockets as you call them) and the crank pulley lines up, everything is okay.
After you get the belt installed and tensioned, rotate the crank from TDC to TDC and check alignment.
1. The notch on the crank pulley should line up with the "0" mark on the timing belt cover (the cover behind the crank pulley).
2. The 2 cam gears (sprockets) should line up with the marks on the backing plate (back timing belt cover).
If both conditions check out, your fine.
If not, you didn't line up the crank pulley and/or cam gears correctly. In which case you must remove the belt, align crank + cam gears, install belt + tension, and check alignment again by rotating the crank from TDC to TDC.
Also make sure that the belt is installed around whatever pulleys in the correct order and orientation. IE: belt wrap order/orientation.
"Skoolin' the unlearned!"
